This procedure only applies to VSP 7400 Series.
After you configure the advanced-feature-bandwidth-reservation boot flag and reboot with the new configuration, you can use the following procedure to verify that the switch reserved ports for configuring advanced features.
  1. To enter User EXEC mode, log on to the switch.
  2. Display the Advanced Feature Bandwidth Reservation mode and reserved ports:
    show sys-info
Switch#show sys-info
General Info :
SysDescr     : Switch1 (w.x.y.z)   BoxType: Switch1
SysName      : Switch1
Advanced Feature Bandwidth Reservation:
Reservation Mode : low
Port Usage Info  : 1/31 and 1/32 are not available to use
