Display information about BGPv6 routes.
  1. To enter User EXEC mode, log on to the switch.
  2. Enter Privileged EXEC mode:
    enable
  3. Display information about BGP routes:
    show bgp ipv6 route [<WORD 1-256> [longer-prefixes]] [community <enable|disable>] [ipv6 <WORD 1-256>] [vrf <WORD 1-16>] [vrfids <0-255>]
The following table defines parameters for the show bgp ipv6 route command.
Variable
Value
[<WORD 1-256>]
Specifies the IPv6 prefix and the prefix length (must be an integer value between 0 and 128).
Enables or disables the display of community attributes.
ipv6 <WORD 1-256>]
Specifies an IPv6 address.
longer-prefixes
Shows long prefixes. The longer-prefixes indicate the mask length from any specified prefix to 128 (for example, show from prefix X:X::X:X/len to X:X::X:X/ 128).
vrf
Specifies a VRF instance by name (the string length ranges from 1–16 characters).
vrfids
Specifies a range of VRFs by ID number (the ID ranges from 0–255).
