This procedure only applies to XA1400 Series.If you downgrade to an earlier release that does not support this feature, you must disable the feature and save the configuration. You must have a compatible configuration file if you downgrade to an earlier release.
enable
configure terminal
logical-intf isis <1–255>
Disable IPsec and IPsec fragementation before encryption and verify the configuration:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#logical-intf isis 2 Switch:1(config-isis-2-192.168.20.1)#no ipsec Switch:1(config-isis-2-192.168.20.1)#no ipsec fragment-before-encrypt Switch:1(config-isis-2-192.168.20.1)#ipsec Switch:1(config-isis-2-192.168.20.1)#show isis logical-interface ipsec ======================================================================================================================================== ISIS Logical Interface IPSec ======================================================================================================================================== ID Status Auth-Method Auth-Key ESP Responder-Only Remote NAT IP Auth-Key-Len Compression Frag-before-encrypt ----------------------------------------------------------------------------------------------------------------------------------------- 1 Enable RSA-SIG ****** aes128gcm16-sha256 False - 128 False False ----------------------------------------------------------------------------------------------------------------------------------------- 1 out of 1 Total Num of Logical ISIS interfaces ----------------------------------------------------------------------------------------------------------------------------------------- ====================================================================================================================== IPSec Tunnel General Info ====================================================================================================================== IPSec tunnel global source-ip-address : 203.0.113.1 ====================================================================================================================== ISIS IPSec Tunnels ====================================================================================================================== ID IPSec source IP IPSec Dst Ip TUNNEL_NEXT_HOP type address PORT/MLT VLAN VRF ---------------------------------------------------------------------------------------------------------------------- 1 global 203.0.113.1 100.100.100.6 Port1/6 100 GlobalRouter ---------------------------------------------------------------------------------------------------------------------- 1 out of 1 Total Num of Logical ISIS interfaces
