View topology message status to view the interconnections between Layer 2 devices in a network.
In the following example, the column “ChassisType” uses a generic name. When you use the show autotopology nmm-table, your switch displays the actual chassis type.
Switch:1(config)#show autotopology nmm-table ========================================================================================== Topology Table ========================================================================================== Local Rem Port IpAddress SegmentId MacAddress ChassisType BT LS CS Port ------------------------------------------------------------------------------------------ 0/0 192.0.2.81 0x000000 0030ab707a00 ChassisType 1 12 Yes HtBt 0/0 1/1 192.0.2.81 0x000000 0050ea268800 ChassisType 2 12 Yes HtBt 1/50 1/42 192.0.2.81 0x000000 070ab307aa00 ChassisType 3 12 Yes HtBt 1/1 2/1 192.0.2.81 0x000000 0030ab57ab00 ChassisType 4 12 Yes HtBt 1/49 2/2 192.0.2.81 0x000000 0030ab307af0 ChassisType 5 12 Yes HtBt 1/50 2/41 192.0.2.81 0x000000 00e0ba327c00 ChassisType 6 12 Yes HtBt 2/1 2/42/1 192.0.2.81 0x000000 0050eb127400 ChassisType 7 12 Yes HtBt 1/2
When a peer switch is running an older software version that does not include support for SONMP hello messages with channelization information, it can only show the slot/port. It cannot show the sub-port.
