Use the following procedure to link an IPsec policy to an interface, and configure a policy direction. By default, the direction is both.
  • You must enable IPsec on the interface first, and then you link the IPsec policy to the interface.
You cannot delete or modify an IPsec policy if the policy links to a port or VLAN interface. If you need to modify the policy, first unlink the policy from the port or VLAN interface.
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    followed by one of the following:
    • interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
    • interface loopback <1–256>
    • interface vlan <1–4059>
  2. Link the IPsec policy to an IPv4 interface:
    ip ipsec policy WORD<1–32> dir <both|in|out>
  3. Link the IPsec policy to an IPv6 interface:
    ipv6 ipsec policy WORD<1–32> dir <both|in|out>
Link the IPsec policy newpolicy to the IPv6 interface VLAN 100:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface vlan 100
Switch:1(config-if)#ipv6 ipsec policy newpolicy dir both
The following table defines parameters for the ip ipsec policy and ipv6 ipsec policy commands.
Variable
Value
WORD<1–32>
Specifies the policy ID.
dir <both|in|out>
Specifies the direction you want to protect with IPsec:
  • both—Specifies both ingress and egress traffic.
  • in—Specifies ingress traffic.
  • out—Specifies egress traffic.
The default is both.
