Perform this procedure to configure Multi-area SPB Distributed Virtual Routing (DvR) backbone redistribution on the switch.
  1. Enter IS-IS Router Configuration mode:
    enable
    configure terminal
    router isis
  2. Configure IS-IS Multi-area SPB DvR backbone redistribution:
    multi-area dvr redistribute backbone
Configuring Multi-area SPB DvR backbone redistribution:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router isis
Switch:1(config-isis)#multi-area dvr redistribute backbone
What to do next
To verify the configuration, see Display IS-IS Multi-area SPB DvR Configuration.
