Configure LST
Use this procedure to configure LST groups.
- Select Link State Tracking
- Select the Link State Tracking tab.
- Select a GroupId row to configure.
- To add upstream ports to the LST group, double click UpstreamPortList, select the upstream ports to add, and then click OK.
- To add downstream ports to the LST group, double click DownstreamPortList, select the upstream ports to add, and then click OK.
- To add an upstream MLT to the LST group, double click UpstreamMltList, and then enter an upstream MLT ID.
- To add a downstream MLT to the LST group, double click DownstreamMltList, and then enter an upstream MLT ID.
- To enable an LST group, double click Enabled, and then select true.
- To activate the LST group configuration, select Apply.
- View the OperState of the LST groups to verify the current operating state.
Link State Tracking field descriptions
Use the data in the following table to use the Link State Tracking tab.
Name |
Description |
GroupId |
Specifies the LST group number between 1 and 48. |
Enabled |
Specifies if the LST group is enabled. Values are true or false. Default is false. |
UpstreamPortList |
Specifies upstream interface ports in the LST group. |
DownstreamPortList |
Specifies downstream interface ports in the LST group. |
UpstreamMltList |
Specifies an upstream multi-link trunk in the LST group. |
DownstreamMltList |
Specifies a downstream multi-link trunk in the LST group. |
OperState |
Displays the current operating status of the LST group. Values are up, down, or notConfigured. |
