Reset the platform to reload system parameters from the most recently saved configuration file. Use the following procedure to reset the device using EDM.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select Chassis.
  3. Select the System tab.
  4. From ActionGroup1, select saveRuntimeConfig.
  5. Select Apply.
  6. From ActionGroup4, select softReset .
  7. Select Apply.
