Use the following procedure to display multiple host status for a port.
- Select 802.1X – EAPOL.
- Select the MultiHost Status tab.
MultiHost Status Field Descriptions
The following table describes values on the MultiHost Status tab.
Name |
Description |
PortNumber |
Indicates the port number associated with this port. |
ClientMACAddr |
Indicates the MAC address of the client. |
PaeState |
Indicates the current state of the authenticator PAE state machine. |
VlanId |
Indicates the VLAN assigned to the client. |
Priority |
Specifies the priority associated with this client MAC. This priority could be the Radius assigned priority or the port QOS level. |
SwUniBindings Note: Exception: Not supported on
VSP 4450
Series, VSP 8600
Series, or XA1400
Series.
Indicates the Extensible Authentication Protocol (EAP) VLAN:ISID bindings that the switch represents as an hexadecimal value. |
IsidSource Note: Exception: Not supported on
VSP 4450
Series, VSP 8600
Series, or XA1400
Series.
Indicates the origin of I-SID value:
AclId Note: Exception: Not supported on
VSP 4450
Series, VSP 8600
Series, or XA1400
Series.
Indicates the dynamic Access Control List (ACL) on the specific port. |
AceIdList
on VSP 4450
Series, VSP 8600
Series, or XA1400
Series.
Indicates the list of dynamic Access Control Entries (ACE) on the specific port. |
DynamicSettings |
Displays the Dynamic settings received from the Remote Authentication Dial-In User Service (RADIUS) server. |
MhsaDynamic |
Specifies whether or not the switch receives the MHSA VSA settings from RADIUS. |
