Configure VNID Endpoints
Exception: only supported on VSP 7200 Series, VSP 7400 Series, VSP 8200 Series, and VSP 8400 Series.
Use the following procedure to configure a VNID and the VXLAN tunnel end point.
- Select VTEP.
- Select the Vnid End Points tab.
- In the Vnid field, type the VNID ID.
- In the VtepId field, type the ID of the remote VTEP.
- Select Apply.
Vnid End Points field descriptions
Use the data in the following table to use the Vnid End Points tab.
Name |
Description |
Vnid |
Specifies a value that uniquely identifies the VNID of this VXLAN tunnel end point. |
VtepId |
Specifies an index value in the range from 1 to 500 that uniquely identifies this remote VTEP. |
Isid |
Displays a value that uniquely identifies the I-SID associated with this VXLAN tunnel end point. |
