Display individual bridging statistics for specific ports to manage network performance.
![Note](images/note.png)
This command is only available on XA1400 Series.
================================================================================ Port Stats Bridge ================================================================================ PORT IN_FRAME IN_FRAME IN_FRAME OUT_FRAME IN_FRAME OUT_FRAME IN_DISCARD NUM UNICAST MULTICAST BROADCAST xSTP BPDU xSTP BPDU -------------------------------------------------------------------------------- 1/1 179325 0 0 119310 179325 0 0 1/2 187951 26078 42 689486 179324 0 25617 1/3 0 0 0 0 0 0 0 1/4 0 0 0 0 0 0 0 1/5 0 0 0 0 0 0 0 1/6 394 0 0 948942 360 0 0 1/7 4689 0 0 863403 360 0 0 1/8 4369 3206 116 958752 360 0 3995 1/9 0 0 0 0 0 0 0 1/10 0 0 0 0 0 0 0 1/11 0 0 0 0 0 0 0 1/12 0 0 0 0 0 0 0 1/13 179325 0 0 42040 179325 0 0 1/14 187864 0 0 50437 179324 0 0 1/15 0 0 0 0 0 0 0 1/16 0 0 0 0 0 0 0 --More-- (q = quit)
Use the data in the following table to use the show interfaces GigabitEthernet statistics bridging command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
