Perform this procedure to configure FA authentication for ports that are operating in Auto-sense mode.
    enable
    configure terminal
  2. Configure the FA authentication key:
    auto-sense fa authentication-key WORD<0-32>
  3. Enable FA message authentication:
    auto-sense fa message-authentication
Configuring FA message authentication globally:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#auto-sense fa message-authentication
The following table defines parameters for the auto-sense fa command.
Variable
Value
Specifies the authentication key value.
Enables Fabric Attach (FA) message authentication globally, for ports that operate in Auto-sense mode.
