Display detailed statistics for specific ports to manage network performance.
Slot and port information can differ depending on hardware platform.
View statistics for various ports:
Switch:1>enable Switch:1#show interfaces gigabitethernet statistics verbose Please widen the terminal for optimal viewing of data. =========================================================================================== Port Stats Interface Extended =========================================================================================== PORT_NUM IN_UNICST OUT_UNICST IN_MULTICST OUT_MULTICST IN_BRDCST OUT_BRDCST IN_LSM OUT_LSM ------------------------------------------------------------------------------------------- 2/1 0 0 0 0 0 0 0 0 2/2 0 0 0 0 0 0 0 0 2/3 0 0 0 0 0 0 0 0 2/4 0 0 0 0 0 0 0 0 2/5 0 0 0 0 0 0 0 0 2/6 0 0 0 0 0 0 0 0 3/1 0 0 0 0 0 0 0 0 3/2 0 0 0 0 0 0 0 0 3/3 0 0 8702 34805 0 0 0 0 3/4 0 0 0 0 0 0 0 0 3/5 0 0 0 0 0 0 0 0 3/6 0 0 0 0 0 0 0 0 3/7 0 0 0 0 0 0 0 0 3/8 0 0 0 0 0 0 0 0 3/9 0 0 0 0 0 0 0 0 --More-- (q = quit)
Use the data in the following table to use the show interfaces GigabitEthernet statistics verbose command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
