Perform this procedure to display the IPsec encryption statistics on the Fabric IPsec Gateway Virtual Machine (VM).
  1. Enter Fabric IPsec Gateway Configuration mode:
    enable
    virtual-service WORD<1-128> console
    Type CTRL+Y to exit the console.
  2. Display IPsec encryption statistics:
    show ipsec-stats
Displaying IPsec encryption statistics on Fabric IPsec Gateway VM:
Switch:1> enable
Switch:1# virtual-service figw console
Connected to domain figw
Escape character is ^Y
  <cr>
FIGW> show ipsec-stats
src 192.0.2.30 dst 192.0.2.40
        proto esp spi 0xc0c2d9cd(3233995213) reqid 1(0x00000001) mode tunnel
        replay-window 32 seq 0x00000000 flag af-unspec (0x00100000)
        aead rfc4106(gcm(aes)) 0xa9c1923a4b4c5618ea2f3596de821261218bdea2 (160 bits) 128
        anti-replay context: seq 0x0, oseq 0x138, bitmap 0x00000000
        lifetime config:
          limit: soft (INF)(bytes), hard (INF)(bytes)
          limit: soft (INF)(packets), hard (INF)(packets)
          expire add: soft 3268(sec), hard 3600(sec)
          expire use: soft 0(sec), hard 0(sec)
        lifetime current:
          475650(bytes), 312(packets)
          add <<yyyy-mm-dd>> <<hh:mm:ss>> use <<yyyy-mm-dd>> <<hh:mm:ss>>
        stats:
          replay-window 0 replay 0 failed 0
src 192.0.2.40 dst 192.0.2.30
        proto esp spi 0xc92b08e5(3375040741) reqid 1(0x00000001) mode tunnel
        aead rfc4106(gcm(aes)) 0x9ca3568095298cefaaa709b9b932eb5141bd252c (160 bits) 128
        anti-replay context: seq 0x135, oseq 0x0, bitmap 0xffffffff
        lifetime config:
          expire add: soft 3341(sec), hard 3600(sec)
        lifetime current:
          470953(bytes), 309(packets)
        stats:
