Perform this procedure to configure the global source IP address for IPsec tunnel on the switch.
Product Notice: This procedure only applies to XA1400 Series switches.
Configuring source IP address for IPsec tunnel.Switch:1>enable Switch:1#configure terminal Switch:1(config)#router isis Switch:1(config-isis)#ipsec tunnel-source-address 192.0.2.10
The following table defines the variable for ipsec tunnel-source-address command.
Variable | Value |
{A.B.C.D} | Specifies the global IP address for IPsec tunnel, which is configured on the same VRF as the source address for IP tunnel. |
