Configuring static forwarding
Configure static forwarding to specify the group of ports that are allowed to forward frames.
Important
Entries are valid for unicast and for group/broadcast addresses.
- Click VLANs.
- Select the Basic tab.
- Select a VLAN.
- Click Bridge.
- In the Bridge, VLAN tab, click the Static tab.
- Click Insert.
- In the MacAddress box, enter a forwarding destination MAC address.
- In the Port box, click the ellipsis button (...).
- Select the port on which the frame is received.
- Click Ok.
- Click Insert.
Static field descriptions
Use the data in the following table to use the Static tab.
Name |
Description |
MacAddress |
Specifies the destination MAC address in a frame to which the forwarding information for this entry applies. This object can take the value of a unicast address. |
Port |
Specifies the port number of the port on which the frame is received. |
VlanId |
Status |
Specifies the status of the VLAN. |
