Enable a CLI User
DEMO FEATURE - Multiple CLI Users Per Role is a demonstration feature on some products. Demonstration features are provided for testing purposes. Demonstration features are for lab use only and are not for use in a production environment. For more information on feature support, see Fabric Engine and VOSS Feature Support Matrix.
Perform this procedure to enable a user after you disable it using the Command Line Interface (CLI).
    enable
    configure terminal
  2. Enable the user:
    username WORD<1-20> enable
Enable the CLI user after disabling it on the switch:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#username add test level rwa enable
Switch:1(config)#no username test enable
Switch:1(config)#username test enable
