Use the following procedure to display the default values used for the SPB-PIM Gateway interface HELLO and JOIN PRUNE intervals unless specifically configured on the individual interface.
  1. In the navigation pane, expand Configuration > IP.
  2. Click SPB-PIM-GW.
  3. Click the Globals tab.
Globals field descriptions
Use the data in the following table to use the Globals tab.
Name
Description
HelloInterval
Displays the PIM HELLO transmission interval.
JoinPruneInterval
Displays the PIM JOIN PRUNE transmission interval.
