Use the following procedure to view the DHCP Snooping interface information.
  1. To enter User EXEC mode, log on to the switch.
  2. Display DHCP Snooping brouter port information:
    show ip dhcp-snooping interface [ gigabitEthernet [ {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} [ vrf WORD<1-16> | vrfids WORD<0-512> ] | <1-4059> [ {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} [ vrf WORD<1-16> | vrfids WORD<0-512> ] | vrf WORD<1-16> | vrfids WORD<0-512> ] | vrf WORD<1-16> | vrfids WORD<0-512> ] ]
  3. Display DHCP Snooping VLAN information:
    show ip dhcp-snooping vlan <1-4059>
  4. Display DHCP Snooping information for specific VRF name:
    show ip dhcp-snooping vrf WORD<1-16>
  5. Display DHCP Snooping information for specific VRF ID:
    show ip dhcp-snooping vrfids WORD<0-512>
Switch:1>show ip dhcp-snooping interface gigabitEthernet
                          Dhcp Snooping Interface Info
PORT       PORT            TRUNK
NUM        CLASS           ID
1/1        UNTRUSTED       none
1/2        UNTRUSTED       none
2/1        UNTRUSTED       none
2/2        UNTRUSTED       none
2/3        UNTRUSTED       none
2/4        UNTRUSTED       none
2/5        UNTRUSTED       none
2/6        UNTRUSTED       none
2/7        UNTRUSTED       none
2/8        UNTRUSTED       none
2/9        UNTRUSTED       none
2/10       UNTRUSTED       none
2/11       UNTRUSTED       none
2/12       UNTRUSTED       none
2/13       UNTRUSTED       none
2/14       UNTRUSTED       none
All 16 out of 16 Total Num of Dhcp Snooping entries displayed
Switch:1>show ip dhcp-snooping vlan
                            Dhcp Snooping Vlan Info
VLAN       VRF
ID         NAME            ENABLE       ORIGIN
1          GlobalRouter    false        RADIUS
10         GlobalRouter    false        RADIUS
4051       GlobalRouter    false        RADIUS
4052       GlobalRouter    false        RADIUS
All 4 out of 4 Total Num of Dhcp Snooping entries displayed
Switch:1>show ip dhcp-snooping binding vrfids 0
                                              DHCP Snooping Binding Table
MAC                       IP              PORT    VLAN    VRF             LEASE      EXPIRY     ENTRY
ADDRESS                   ADDRESS         NUM     ID      NAME            TIME       TIME       TYPE
36:63:0e:73:03:fe         192.0.2.8       2/10/2  200     GlobalRouter    86400      83700      Learned
36:63:0e:73:03:ff         192.0.2.9       2/10/2  200     GlobalRouter    86400      83700      Learned
Static entries  : 0
Learned entries : 2
Total entries   : 2
All 2 out of 2 Total DHCP Snooping binding entries displayed
Switch:1>show ip dhcp-snooping binding vrf vrf100
00:00:00:00:01:01         192.0.2.11      2/30    100     vrf100          Infinite   none       Static
Static entries  : 1
Learned entries : 0
Total entries   : 1
All 1 out of 3 Total DHCP Snooping binding entries displayed
