View MLT statistics to display MultiLinkTrunking statistics for the switch or for the specified MLT ID.
Switch:1#show mlt stats ================================================================================ Mlt Interface ================================================================================ ID IN-OCTETS OUT-OCTETS IN-UNICST OUT-UNICST -------------------------------------------------------------------------------- 1 256676904 183670662 1397 456 2 61737348498 61584347982 1450182 1490619 4 229256124 47472778 0 0 100 251678170 32332107 0 0 ID IN-MULTICST OUT-MULTICST IN-BROADCST OUT-BROADCST MT -------------------------------------------------------------------------------- 1 2419514 2295274 41 268194 E 2 962303832 960067410 765 237 E 4 2159884 666153 0 90 E 100 2095269 504965 13 0 E ID IN-LSM OUT-LSM -------------------------------------------------------------------------------- 1 0 0 2 957925732 957929399 4 0 0 --More-- (q = quit)
Use the data in the following table to help you use the show mlt stats command.
Variable |
Value |
<1-512> |
Specifies the MLT ID. |
