This procedure only applies to XA1400 Series.Configure IPsec fragmentation before encryption to avoid possible throughput penalty for sending fragmented packets over the Internet.
Configure the IPsec tunnel source address globally.
Disable IPsec on the logical interface.
IPsec over Fabric Extend must be in IPsec decoupled mode. For more information, see Fabric IPsec Gateway Fundamentals.
Configure one of the following:
the IPsec tunnel destination IP
IPsec NAT-T responder only mode
IPsec responder remote NAT IP address
enable
configure terminal
logical-intf isis <1–255>
Enable IPsec fragment before encryption and verify the configuration:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#logical-intf isis 2 Switch:1(config-isis-2-192.0.2.24)#ipsec fragment-before-encrypt Switch:1(config-isis-2-192.0.2.24)#ipsec
Switch:1>show isis logical-interface ipsec ======================================================================================================================================= ISIS Logical Interface IPSec ======================================================================================================================================= ID Status Auth-Method Auth-Key ESP Responder-Only Remote NAT IP Auth-Key-Len Compression Frag-before-encrypt --------------------------------------------------------------------------------------------------------------------------------------- 1 Enable RSA-SIG ****** aes128gcm16-sha256 False - 128 False True --------------------------------------------------------------------------------------------------------------------------------------- 1 out of 1 Total Num of Logical ISIS interfaces --------------------------------------------------------------------------------------------------------------------------------------- ====================================================================================================================== IPSec Tunnel General Info ====================================================================================================================== IPSec tunnel global source-ip-address : 203.0.113.1 ====================================================================================================================== ISIS IPSec Tunnels ====================================================================================================================== ID IPSec source IP IPSec Dst Ip TUNNEL_NEXT_HOP type address PORT/MLT VLAN VRF ---------------------------------------------------------------------------------------------------------------------- 1 global 203.0.113.1 100.100.100.6 Port1/6 100 GlobalRouter ---------------------------------------------------------------------------------------------------------------------- 1 out of 1 Total Num of Logical ISIS interfaces ----------------------------------------------------------------------------------------------------------------------
