Add a RADIUS server to provide RADIUS service on the switch.
RADIUS supports IPv4 and IPv6 addresses, with no difference in functionality or configuration using CLI.
Add a RADIUS server:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#radius server host 4717:0000:0000:0000:0000:0000:7933:0001 key testkey1 used-by snmp port 12 retry 5 timeout 10 enable
The following table defines parameters for the radius server host command.
                                 Variable  |
                                 Value  |
                                 used-by {cli|eapol|endpoint-tracking|snmp|web}  |
                                 Configures how the server functions:
 The default is cli.  |
                                 host WORD <0–46>  |
                                 Configures a host server. WORD <0–46> signifies an IPv4 address in the format A.B.C.D or an IPv6 address in the format x:x:x:x:x:x:x:x. RADIUS supports IPv4 and IPv6 addresses, with no difference in functionality or configuration using CLI.  |
                                 acct-enable  |
                                 Enables RADIUS accounting on this server. The system enables RADIUS accounting by default.  |
                                 acct-port <1-65536>  |
                                 Configures the UDP port of the RADIUS accounting server. The
                                    default value is 1813.
                            Important:
                                The UDP port value set for the client must match the UDP value set for the RADIUS server.  |
                                 enable  |
                                 Enables the RADIUS server. The default is true.  |
                                 key WORD<0–32>  |
                                 Configures the secret key of the authentication client.  |
                                 port <1-65536>  |
                                 Configures the UDP port of the RADIUS authentication server. The default value is 1812.  |
                                 priority <1–10>  |
                                 Configures the priority value for this server. The default is 10.  |
                                 retry <0–6>  |
                                 Configures the number of authentication retries the server will accept. The default is 3.  |
                                 secure-enable  |
                                 Enable RADIUS Security (RADSec).  |
                                 secure-log-level  |
                                 Specifies the log severity level. Possible values are :
                                 secure-mode  |
                                 Specifies the protocol used for secure connection to the server.  |
                                 secure-profile  |
                                 Configures the secure profile for the server.  |
                                 timeout <1–180>  |
                                 Configures the number of seconds before the authentication request times out. The default is 8.  |
