To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
Configure inbound filtering on a RIP interface to determine whether to learn a route on a specified interface and to specify the parameters of the route when it is added to the routing table. Configure outbound filtering on a RIP interface to determine whether to advertise a route from the routing table on a specified interface and to specify the parameters of the advertisement.
The port on which the multimedia filter is enabled becomes a DIFFSERV access port.
- Select Policy.
- Select the RIP In/Out Policy tab.
- In the desired row, double-click the InPolicy or OutPolicy column.
- Select a preconfigured In/Out policy, and then select OK.
RIP In/Out Policy field descriptions
Use the data in the following table to use the RIP In/Out Policy tab.
Name | Description |
Address | Specifies the IP address of the RIP interface. |
Interface | Specifies the internal index of the RIP interface. |
InPolicy | Specifies the policy name used for inbound filtering on this RIP interface. This policy determines whether to learn a route on this interface and specifies the parameters of the route when it is added to the routing table. |
OutPolicy | Specifies the policy name used for outbound filtering on this RIP interface. This policy determines whether to advertise a route from the routing table on this interface and specifies the parameters of the advertisement. |
