Perform this procedure to control USB access. For security reasons, you may want to disable this port to prevent individuals from using it. By default, the port is automatically mounted when a USB device is inserted.
The switch must be in Enhanced Secure mode.
enable
configure terminal
sys usb disable
no sys usb disable
