Link Layer Discovery Protocol (LLDP) stations that connect to a local area network (LAN) advertise the station capabilities to each other, allowing the discovery of physical topology information for network management. When the system enables a switch as a Fabric Attach (FA) server in the Shortest Path Bridging (SPB) network, it receives LLDP messages from the FA Client and the FA Proxy devices using the LLDP Fabric Connect Type-Length-Value (TLV). For more information, see LLDP Fabric Connect TLV.
Following are the steps to create an Intermediate-System-to-Intermediate-System (IS-IS) adjacency between the VSP 8600 Series and Auto-sense switches.
On the VSP 8600 Series switch:
  1. Disable the High Availability-CPU mode.
  2. Enable the Shortest path bridging MAC (SPBM) mode.
  3. Create an SPBM instance.
  4. Create an SPBM B-VLAN.
  5. Configure the port that links to the VOSS switch.
On the VOSS switch:
  1. Enable the Shortest path bridging MAC (SPBM) mode.
  2. Enable Auto-sense on the port that links to the VSP 8600 Series switch.
Create an IS-IS adjacency:
enable
configure terminal
no boot config flags ha-cpu
boot config flags spbm-config-mode
spbm
router isis
spbm 1
spbm 1 b-vid 100,101 primary 100
spbm 1 nick-name 1.44.66
manual-area c1
exit
vlan create 100 type spbm-bvlan
vlan create 101 type spbm-bvlan
vlan members remove 1 1/3
interface gigabitEthernet 1/3
isis
isis spbm 1
isis enable
router isis enable
On the VOSS switch:
enable
configure terminal
auto-sense enable
1 YYYY-MM-DD HH:MM:SS.622Z Switch - 0x00374589 - 00000000 GlobalRouter FA INFO Fabric Attach Assignments will
be rejected since ISIS is disabled.
1 YYYY-MM-DD HH:MM:SS.779Z Switch - 0x001dc703 - 00000000 GlobalRouter ISIS INFO B-VLANs (100,101) dynamically
learnt through LLDP. ISIS Restarted
1 YYYY-MM-DD HH:MM:SS.779Z Switch - 0x002d0609 - 00000000 GlobalRouter LLDP INFO New LLDP Neighbor Discovered
on interface 1/3
1 YYYY-MM-DD HH:MM:SS.954Z Switch - 0x00004727 - 00000000 GlobalRouter SNMP INFO SPBM detected adj INIT on
Port1/3, neighbor f873.a201.03df
1 YYYY-MM-DD HH:MM:SS.984Z Switch - 0x00004727 - 00000000 GlobalRouter SNMP INFO SPBM detected adj UP on
show isis adjacencies
                                              ISIS Adjacencies
INTERFACE  L STATE  UPTIME    PRI  HOLDTIME   SYSID               HOST-NAME       STATUS   AREA       AREA-NAME
Port1/3    1 UP     00:05:18  127   21        f873.a201.03df      VSP-8608        ACTIVE   HOME
Home:   1 out of 1 interfaces have formed an adjacency
