Use the following commands to display key health information about the types of control packets and protocols received on a port and sent to the control processor.
- In the Device Physical View, select a port.
- Click Port.
- Click the CPP Stats tab.
CPP Stats Field Descriptions
Use the data in the following table to use the CPP Stats tab.
Name |
Description |
Port |
Identifies the slot and port. |
Packet |
Shows the packet type. |
PacketName |
Shows the name of the packet. |
RxPackets |
Indicates the number of received packets on the port for the packet type. |
TxPackets |
Indicates the number of transmitted packets on the port for the packet type. |
