Enable VRRP Global Variables
Enable VRRP global variables to enable the VRRP function.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
- Select VRRP.
- Select the Globals tab.
- Configure the required features.
- Select Apply.
Globals field descriptions
Use the data in the following table to use the Globals tab.
Name |
Description |
NotificationCntl |
Indicates whether the VRRP-enabled router generates SNMP traps
for events.
The default is enabled. |
PingVirtualAddrEnable |
Configures whether this device responds to pings directed to a virtual router IP address. The default is enabled. |
