Perform this procedure to view the maximum MAC learning limit information for an I-SID.
Important
The command show i-sid limit-fdb-learning is supported only on the VSP 4450 Series.
The total MAC learning limit per switch is 32000. MAC learning on I-SID stops when the maximum limit is reached.
show i-sid limit-fdb-learning <1-16777215>
View maximum MAC learning limit for all I-SIDs.
Switch:1#show i-sid limit-fdb-learning ========================================= Isid MAC-Limit Info ========================================= ISID MAC-LIMIT MAXMAC ID STATUS COUNT ----------------------------------------- 10 disabled 32000 11 disabled 32000 12 disabled 32000 15 disabled 32000 101 disabled 32000 All 5 out of 5 Total Num of i-sid Info displayed
View maximum MAC learning limit for a specific I-SID.
Switch:1#show i-sid limit-fdb-learning 10 ========================================= Isid MAC-Limit Info ========================================= ISID MAC-LIMIT MAXMAC ID STATUS COUNT ----------------------------------------- 10 disabled 32000 All 1 out of 1 Total Num of i-sid Info displayed
Variable definitions
The following table defines parameters for the show i-sid limit-fdb-learning command.
Important
Variable |
Value |
limit-fdb-learning |
Displays the I-SID-based maximum MAC limit information. |
<1–6777215> |
Displays the service interface identifier (I-SID). The I-SID range is 1 to 16777215. |
