Perform this procedure to display the IS-IS remote area configuration on the switch.
  1. To enter User EXEC mode, log on to the switch.
  2. Display IS-IS remote configuration:
    show isis remote
Displaying IS-IS remote area information:
Switch:1>show isis remote
                             ISIS Remote Area Info
	                    AdminState  : disabled
                             System ID : 209e.f77e.2086
                     Num of Interfaces : 4
                 Num of Area Addresses : 1
              Dynamically Learned Area : 49.0002
                  Multi-Area OperState : designated
