View a summary of BGP peering over IPv6 transport.
The following example shows partial output for the show bgp ipv6 summary command.
Switch:1>show bgp ipv6 summary vrf vrf1 ============================================================================= BGP ipv6 Summary - VRF vrf1 ============================================================================= BGP version - 4 local-as - 200 Identifier - 0.0.0.6 Decision state - Idle The total number of routes is 1 BGPv6 NEIGHBOR INFO : NEIGHBOR RMTAS STATE HLDTM KPALV HLDCFG KPCFG WGHT CONRTY ADVINT ------------------------------------------------------------------------------------------------ 2001:DB8:0:0:0:0:0:ffff 50 Established 180 60 180 60 100 120 5 Total bgpv6 neighbors: 1 BGP CONFEDERATION INFO : confederation identifier 0 confederation peer as BGPv6 NETWORK INFO : ===================================================================== BGPv6 Networks - VRF vrf1 ===================================================================== )
The following table defines parameters for the show bgp ipv6 summary command.
Variable |
Value |
vrf |
Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
vrfids |
Specifies a range of VRFs by ID number (the ID ranges from 0–255). |
