Use this procedure if you need to downgrade or upgrade from a release that supports different key sizes.
Different releases can support different DSA host key, RSA host key, and DSA user key sizes. If you need to upgrade or downgrade to an earlier release that does not support the same key size, you must delete all of the keys from the .ssh directory and generate new keys for SSH. If you do not do this, key sizes that are no longer supported will no longer function.
You only need to perform this procedure if you have previously generated DSA host, RSA host, or DSA user keys with a release that supports different key sizes.
no ssh
cd /intflash/.ssh
ssh_dss.key ssh_rsa.key moc_sshc_dsa_file moc_sshc_rsa_file id_dsa_rwa id_dsa_rwa.pub id_rsa_rwa id_rsa_rwa.pub moc_sshc_dsa_file_fed moc_sshc_rsa_file_fed known_hosts ssh_ecdsa.key dsa_key_<access level like rwa/rw/ro/admin/security/privilege/operator/auditor>, example: dsa_key_rwa rsa_key_<access level like rwa/rw/ro/admin/security/privilege/operator/auditor>, example: rsa_key_rwa
ssh dsa-host-key [<1024–1024>]
ssh dsa-user-key WORD<1–15> [size <1024–1024>]
ssh rsa-host-key [<1024–2048>]
