Use this procedure to display the MAC addresses that are learned or statically configured for a VLAN. In order to learn you have to be connected to another switch or host and receive some traffic.
The VSP 4450 Series does not display a log message when MAC learning maximum limit is reached.
View VLAN forwarding database information:
Switch:1> show vlan mac-address-entry
================================================================================ Vlan Fdb ================================================================================ VLAN MAC SMLT ID STATUS ADDRESS INTERFACE REMOTE TUNNEL -------------------------------------------------------------------------------- 1 learned f8:15:47:e1:80:0c Port-1/2 false - 2 learned 32:20:d3:81:00:77 Port-1/9 false - 4 learned b4:a9:5a:2b:78:31 Port-2/1 false - 3 out of 3 entries in all fdb(s) displayed.
View where entries are learned. The TUNNEL column indicates where in the SPBM network an entry is learned.
Switch:1> show vlan mac-address-entry spbm-tunnel-as-mac
Use the data in the following table to use optional parameters with the show vlan mac-address-entry command.
Variable |
Value |
<1-4059> |
mac <0x00:0x00:0x00:0x00:0x00:0x00> |
Specifies the MAC address. |
port {slot/port[-slot/port][,...]} |
Specifies the port or port list. |
spbm-tunnel-as-mac |
Displays where entries are learned. The TUNNEL column indicates where in the SPBM network an entry is learned. |
