By default, OSPF Helper mode is enabled when OSPF is configured. You can disable helper mode by the following command and re-enable it again by using no or default operators.
  1. Enter OSPF Router Configuration mode:
    enable
    configure terminal
    router ospf
  2. Enter the following command to disable Helper mode:
    helper-mode-disable
  3. Enter the following command to enable Helper mode:
    no helper-mode-disable
    Or
    default helper-mode disable
Disable Helper mode:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router ospf
Switch:1(config-ospf)#helper-mode-disable
Enable Helper mode:
Switch:1>enable
Switch:1(config-ospf)#no helper-mode-disable
