Configure an OVSDB Controller
Exception: only supported on VSP 7200 Series, VSP 7400 Series, VSP 8200 Series, and VSP 8400 Series.
Use the following procedure to configure an OVSDB controller ID, IP address, protocol, and port.
- Select OVSDB.
- Select the Controller tab.
- Select Insert.
- In the Id field, assign a unique index value to this controller.
- In the IpAddr field, enter the IP address of this controller.
- In the Protocol field, select tcp or ssl.
- In the Port field, enter a port number.
- Select Insert.
Controller field descriptions
Use the data in the following table to use the Controller tab.
Name |
Description |
Id |
Specifies an ID number for a controller. Value range of 1 to 100. |
IpAddr |
Specifies the IP address of a controller. Type an IP address in A.B.C.D format. |
Protocol |
Specifies the communications protocol for the controller. Select tcp or ssl. |
Port |
Specifies the communications port for the controller. Value range of 1 to 65535. |
