This procedure only applies to VSP 4900 Series and VSP 7400 Series.
Ensure that both the ACL and the ACE exist.
Perform this procedure to limit the number of packets that can be attached to an ACL ACE. If you want to modify the ingress bandwidth rate limiter values, you must first disable the ACE.
You can attach one policer to ACL and ACE. Every policer is independent.
  1. Enter the Global Configuration mode:
    enable
    configure terminal
  2. Configure an ACL and ACE policer:
    filter acl ace policer <acl-id> <ace-id> svc-rate <0–4000000000> peak-rate <8-4000000000>
    You must configure both svc-rate and peak-rate.
  3. Ensure the configuration is correct:
    show filter acl policer <acl-id> <ace-id>
