Use this procedure to configure the device subject parameters to identify the device. The parameters include name, Email ID, company, department, and location of the subject.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Select Certificate .
  3. Select the Subject or Global Subject tab.
  4. In the CommonName field, type the name of the subject.
  5. Complete the remaining optional configuration to customize the policy.
  6. Select Apply.
Subject field descriptions
Use the data in the following table to use the Subject tab.
Name
Description
CommonName
Specifies the name of the subject sending the Certificate Signing Request to the Certificate Authority.
EmailAddress
Specifies the Email address of the subject sending the Certificate Signing Request to the Certificate Authority.
OrganizationalUnit
Specifies the organizational unit of the subject sending the Certificate Signing Request to the Certificate Authority.
Organization
Specifies the organization of the subject sending the Certificate Signing Request to the Certificate Authority.
Locality
Specifies the locality of the subject sending the Certificate Signing Request to the Certificate Authority.
Province
Specifies the province of the subject sending the Certificate Signing Request to the Certificate Authority.
Country
Specifies the country of the subject sending the Certificate Signing Request to the Certificate Authority.
InstallFile
Installs the specific certificate file type obtained offline from the Certificate Authority.
InstallFileName
Specifies the certificate file name to install.
UninstallFile
Uninstalls the specific certificate file type obtained offline from the Certificate Authority.
UninstallFileName
Specifies the certificate file name to uninstall.
GenerateCsr
Generates the certificate signing request to obtain the offline subject certificate.
