Displays the RIP redistribution configuration information.
View the RIP redistribution configuration information:
Switch(config-ospf)#show ip rip redistribute
                      RIP Redistribute List - GlobalRouter
SRC-VRF          SRC  MET    ENABLE       RPOLICY
GlobalRouter     ISIS 0      FALSE
Variable definitions
The following table defines parameters for the show ip rip redistribute command or the show ipv6 rip redistribute command.
 Variable  |
 Value  |
 vrf WORD<1-16>  |
 Specifies a VRF by name.  |
 vrfids WORD<0-512>  |
 Specifies a range of VRF IDs.  |
