Use the following commands to view Key Health Indicator (KHI) for segmented management instance interface information of the switch.
The type of management interface supported varies by platform. For information about supported Segmented Management Instance interface types, see Fabric Engine and VOSS Feature Support Matrix.
show khi mgmt statistics [clip | oob | vlan]
Switch:1>show khi mgmt statistics
                               Packet Counters - Interface Mgmt-oob
Packet Type                 Rx Packets           Tx Packets           Rx Packets Dropped
Telnet                      1034                 682                  0
Ntp                         0                    0                    173
Dhcp                        0                    0                    837
OtherUdpWellKnown           0                    0                    1182
Arp-reply                   74                   303                  0
Arp-request                 59915                74                   0
IcmpV6-nd-nbr-solicit       0                    1                    0
IcmpV6-nd-router-advert     27                   0                    0
