Use the following procedure to enable ping to a virtual IP address. The default is enabled.
  1. Enter VRRP Router Configuration mode:
    enable
    configure terminal
    router vrrp
  2. Enable ping to a virtual IP address:
    ping-virtual—address enable [vrf WORD<1–16>]
    default ping-virtual—address enable [vrf WORD<1–16>]
  3. Display the configuration:
    show ip vrrp [vrf WORD<1–16>]
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router vrrp
Switch:1(config-vrrp)#ping-virtual-address enable vrf mgmtrouter
Switch:1(config)#show ip vrrp vrf mgmtrouter
VRRP Global Settings - VRF mgmtrouter
ping-virtual-address : enabled
send-trap : enabled
Variable definitions
Use the data in the following table to use the ping-virtual—address enable and show ip vrrp commands.
Variable
Value
enable
Enables ping to a virtual IP address.
vrf WORD<1–16>
Specifies the VRF.
