Use this procedure to configure the RADIUS server reachability settings.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Click RADIUS.
  3. Click the RADIUS Global tab.
  4. In RadiusReachability, select either useStatusServerPackets or useDummyRadiusRequests.
  5. In the UserName field, type the reachability user name.
  6. In the Password field, type the reachability password.
  7. In the Confirm Password field, retype the reachability password.
  8. In the Unreachable Timer field, type the interval in seconds between checks when the RADIUS server is unreachable.
  9. In the KeepAlive Timer field, type the interval in seconds between checks when the RADIUS server is reachable.
  10. Click the Apply.
RADIUS Global Field Descriptions
Use the data in the following table to use the RADIUS Global tab.
Name
Description
Enable
Enables the RADIUS authentication feature globally.
MaxNumberServer
Specifies the maximum number of servers to be used inclusive.
AccessPriorityAttrValue
Specific to RADIUS authentication. Specifies the vendor-specific attribute value of the access-priority attribute to match the type value set in the dictionary file on the RADIUS server. The default is 192.
AcctEnable
Enables RADIUS accounting.
AcctAttriValue
Specific to RADIUS accounting. Specifies the vendor-specific attribute value of the CLI-command attribute to match the type value set in the dictionary file on the RADIUS server. This value must be different from the access-priority attribute value configured for authentication. The default value is 193.
AcctIncludeCli
Specifies whether you want CLI commands included in RADIUS accounting requests.
ClearStat
Clears RADIUS statistics from the device.
McastAttributeValue
Specifies the value of the Mcast attribute. The default value is 90.
AuthInfoAttrValue
Specifies the value of the authentication information attribute. The default value is 91.
CommandAccessAttrValue
Specifies the value of the command access attribute. The default value is 194.
CliCommandAttrValue
Specifies the value of the CLI command attribute. The default value is 195.
AuthInvalidServerAddress
Displays the number of access responses from unknown or invalid RADIUS servers.
CliCmdCount
Gives the value for the CLI command count. The default is 40.
CliProfEnable
Enables RADIUS CLI profiling.
SupportedVendorIds
Shows the vendor IDs that the software supports for RADIUS.
RadiusReachability
Specifies the mode for RADIUS reachability. Status-server mode provides a standard-compliant method for RADIUS reachability. Use-radius mode requires the configuration of dummy packets that are sent to RADIUS servers. The default is use-radius mode.
SecureEnable
Enable RADIUS Security (RADSec).
UserName
Specifies the username for RADIUS server reachability. The default is extremenetworks.
Password
Specifies the password for RADIUS server reachability. The default is extremenetworks.
Confirm Password
Confirms the password for RADIUS server reachability.
Unreachable Timer
Specifies, in seconds, the interval between checks when radius server is unreachable. The default is 60 seconds.
Keep Alive Timer
Specifies, in seconds, the interval between checks when radius server is reachable. The default is 180 seconds.
