KHI information can be cleared globally across the whole device. Use the command to clear the CPP port statistics or Segmented Management Instance statistics.
  1. Enter Privileged EXEC mode:
    enable
  2. Clear CPP statistics:
    clear khi cpp port-statistics
  3. Clear segmented management instance statistics:
    This step does not apply to VSP 8600 Series.
    clear khi mgmt statistics
