This procedure does not apply to VSP 8600 Series or XA1400 Series.
Configure a platform VLAN and associate the Fail Open I-SID.
Use this procedure to configure Fail Open I-SID. If the switch declares the RADIUS servers unreachable, then all new devices gain access into the configured Fail Open I-SID. 0 indicates that Fail Open I-SID is not enabled for this port.
Configure the Fail Open I-SID.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config-if)#interface gigabitEthernet 1/10 Switch:1(config-if)#eapol fail-open-isid 1000
The following table defines parameters for the eapol fail-open-isid command.
Variable |
Value |
<0-16000000> |
Specifies the Fail Open I-SID value. 0 indicates that Fail Open I-SID is not enabled for this port. |
