BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see Fabric Engine and VOSS Feature Support Matrix.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select BFD.
  3. Select the Performance counters tab.
BFDPerformance Counters Field Descriptions
Use the data in the following table to use the Performance counters tab.
Name Description
PktIn
Specifies the total number of BFD messages received for this BFD session.
PktOut
Specifies the total number of BFD messages sent for this BFD session.
