A special CLI command mode provides a set of specific commands that are different in operation and syntax from the standard switch CLI command modes and the commands available in them. For example, a set of CLI commands that configure services on a Virtual Machine (VM).
Special CLI command modes can be hardware dependent. For information about feature support, see Fabric Engine and VOSS Feature Support Matrix.
The following table describes the special command mode.
Table 1. Special CLI Command Mode Summary
Special command mode
Command mode navigation
Command to access mode
Prompt displayed in mode
Description
Fabric IPsec Gateway
Accessible from Privileged EXEC
virtual-service WORD<1-128> console
Note:
Type CTRL+Y to exit the console.
FIGW>
Configure services like IPsec, fragmentation and reassembly, and to manage the Fabric IPsec Gateway VM.
