Use the following procedure to configure a time interval, after which the key exchange takes place.
Configure the SSH rekey time-interval to 3 hours:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#ssh rekey time-interval 3
The following table defines parameters for the ssh rekey time-interval command.
 Variable  |
 Value  |
 <1–6>  |
 Specifies the time-interval for SSH rekeying in hours. The default is 1 hour.  |
