Use this procedure to view NEAP client MAC information on a port.
- In the navigation pane, expand Configuration --> Security --> Data Path.
- Select 802.1X – EAPOL.
- Select NEAP Radius tab.
NEAP Radius Field Descriptions
The following table describes values on the NEAP Radius tab.
Name |
Description |
MacPort |
Indicates the port number associated with this port. |
MacAddr |
Indicates the MAC address of the client. |
MacStatus |
Indicates the authentication status of the NEAP host that is authenticated using the RADIUS server. |
VlanId |
Indicates the VLAN assigned to the client. |
MacClear |
Clears the non EAP MAC entry associated with a specific index. |
MacPriority |
Indicates the priority associated with this Non-EAP client MAC. This priority could be the Radius assigned priority or the port QOS level. |
SwUniBindings Note: Exception: Not supported on
VSP 4450
Series, VSP 8600
Series, or XA1400
Series.
Indicates the VLAN and I-SID bindings. VLAN is represented with 2 bytes and I-SID is represented with 4 bytes. The output is a continuous hexadecimal representation of the VLAN that is followed by the corresponding I-SID. |
IsidSource Note: Exception: Not supported on
VSP 4450
Series, VSP 8600
Series, or XA1400
Series.
Indicates the source of the I-SID value. An I-SID value is generated in one of the following ways:
NonEapAuthType Note: Exception: Not supported on
VSP 4450
Series, VSP 8600
Series, or XA1400
Series.
Indicates the authentication type of the Non-EAP client:
AclId Note: Exception: Not supported on
VSP 4450
Series, VSP 8600
Series, or XA1400
Series.
Indicates the dynamic Access Control List (ACL) on the specific port. |
AceIdList Note: Exception: Not supported on
VSP 4450
Series, VSP 8600
Series, or XA1400
Series.
Indicates the list of dynamic Access Control Entries (ACE) on the specific port. |
DynamicSettings |
Displays the dynamic settings received from the Remote Authentication Dial-In User Service (RADIUS) server and successfully applied on the port or VLAN. |
MhsaDynamic |
Specifies whether or not the switch receives the MHSA VSA settings from RADIUS. |
