View Private VLAN Information
You can view the private VLAN information for the primary and secondary VLANs, I-SIDs, and private VLAN port types.
- Select VLANs.
- Select Private VLAN.
Private VLAN field descriptions
Use the data in the following table to use the Private VLAN tab.
Name |
Description |
Primary Vlan |
Shows the VLAN ID for the primary VLAN. |
Secondary Vlan |
Shows the VLAN ID for the secondary VLAN. |
Primary / Secondary I-sid |
Shows the I-SID for the VLAN. |
