View global VRF status information to determine the number of VRFs that are configured and active.
  1. In the navigation tree, expand the following folders: Configuration > VRF.
  2. Click VRF.
  3. Click the Global Status tab.
Global Status field descriptions
Use the data in the following table to use the Global Status tab.
Name
Description
ConfigNextAvailableVrfId
Specifies the number of the next available Virtual Router ID (index).
ConfiguredVRFs
Specifies the number of VRFs configured on this network element.
ActiveVRFs
Specifies the number of VRFs that are active on the network element. These are VRFs for which the OperStatus is up.
