This section shows examples of configured internal Border Gateway Protocol (iBGP) IPv4 and IPv6 peers over user-created Virtual Routing and Forwarding (VRF) instances.
The Autonomous System (AS) number configured on the global VRF is inherited by all user-created VRFs, however, you can override the AS number for a specific user-created VRF. For more information, see Configure an AS Number for a Non-default VRF.
Configuration on switch 1:
# # VRF CONFIGURATION # ip vrf vrf1 vrfid 1 router vrf vrf1 exit ip vrf vrf2 vrfid 2 router vrf vrf2 exit # # PORT CONFIGURATION - PHASE I # interface GigabitEthernet 1/1 encapsulation dot1q exit # # VLAN CONFIGURATION # vlan members remove 1 1/1,1/46 vlan create 100 type port-mstprstp 0 vlan members 100 1/1 portmember interface Vlan 100 ip address 10.10.10.1 255.255.255.0 1 exit vlan create 101 type port-mstprstp 0 vlan members 101 1/1 portmember interface Vlan 101 vrf vrf1 ip address 11.10.10.1 255.255.255.0 2 exit vlan create 102 type port-mstprstp 0 vlan members 102 1/1 portmember interface Vlan 102 vrf vrf2 ip address 12.10.10.1 255.255.255.0 3 exit # # PORT CONFIGURATION - PHASE II # interface GigabitEthernet 1/1 default-vlan-id 100 no shutdown exit # # CIRCUITLESS IP INTERFACE CONFIGURATION - GlobalRouter # interface loopback 1 ip address 10.1.1.10/32 exit # # CIRCUITLESS IP INTERFACE CONFIGURATION - VRF # interface loopback 2 ip address 11.1.1.11/32 vrf vrf1 exit interface loopback 3 ip address 12.1.1.12/32 vrf vrf2 exit # # BGP CONFIGURATION - GlobalRouter # router bgp no synchronization exit router bgp 1000 enable router bgp network 10.1.1.10/32 metric 100000 neighbor "10.10.10.2" neighbor 10.10.10.2 remote-as 1000 neighbor 10.10.10.2 next-hop-self neighbor 10.10.10.2 update-source 10.10.10.1 neighbor 10.10.10.2 enable exit # # BGP CONFIGURATION - VRF # router vrf vrf1 ip bgp no ip bgp synchronization ip bgp enable ip bgp network 11.1.1.11/32 metric 100000 ip bgp neighbor "11.10.10.2" ip bgp neighbor 11.10.10.2 remote-as 1000 ip bgp neighbor 11.10.10.2 next-hop-self ip bgp neighbor 11.10.10.2 update-source 11.10.10.1 ip bgp neighbor 11.10.10.2 enable exit router vrf vrf2 ip bgp no ip bgp synchronization ip bgp enable ip bgp network 12.1.1.12/32 metric 100000 ip bgp neighbor "12.10.10.2" ip bgp neighbor 12.10.10.2 remote-as 1000 ip bgp neighbor 12.10.10.2 next-hop-self ip bgp neighbor 12.10.10.2 update-source 12.10.10.1 ip bgp neighbor 12.10.10.2 enable exit
Configuration on switch 2:
# # VRF CONFIGURATION # ip vrf vrf1 vrfid 1 router vrf vrf1 exit ip vrf vrf2 vrfid 2 router vrf vrf2 exit # # PORT CONFIGURATION - PHASE I # interface GigabitEthernet 1/1 encapsulation dot1q exit # # VLAN CONFIGURATION # vlan members remove 1 1/1,1/46 vlan create 100 type port-mstprstp 0 vlan members 100 1/1 portmember interface Vlan 100 ip address 10.10.10.2 255.255.255.0 1 exit vlan create 101 type port-mstprstp 0 vlan members 101 1/1 portmember interface Vlan 101 vrf vrf1 ip address 11.10.10.2 255.255.255.0 2 exit vlan create 102 type port-mstprstp 0 vlan members 102 1/1 portmember interface Vlan 102 vrf vrf2 ip address 12.10.10.2 255.255.255.0 3 exit # # PORT CONFIGURATION - PHASE II # interface GigabitEthernet 1/1 default-vlan-id 100 no shutdown exit # # BGP CONFIGURATION - GlobalRouter # router bgp no synchronization exit router bgp 1000 enable router bgp neighbor "10.10.10.1" neighbor 10.10.10.1 remote-as 1000 neighbor 10.10.10.1 next-hop-self neighbor 10.10.10.1 update-source 10.10.10.2 neighbor 10.10.10.1 enable exit # # BGP CONFIGURATION - VRF # router vrf vrf1 ip bgp no ip bgp synchronization ip bgp enable ip bgp neighbor "11.10.10.1" ip bgp neighbor 11.10.10.1 remote-as 1000 ip bgp neighbor 11.10.10.1 next-hop-self ip bgp neighbor 11.10.10.1 update-source 11.10.10.2 ip bgp neighbor 11.10.10.1 enable exit router vrf vrf2 ip bgp no ip bgp synchronization ip bgp enable ip bgp neighbor "12.10.10.1" ip bgp neighbor 12.10.10.1 remote-as 1000 ip bgp neighbor 12.10.10.1 next-hop-self ip bgp neighbor 12.10.10.1 update-source 12.10.10.2 ip bgp neighbor 12.10.10.1 enable exit
# # VRF CONFIGURATION # ip vrf vrf1 vrfid 1 router vrf vrf1 exit ip vrf vrf2 vrfid 2 router vrf vrf2 exit # # PORT CONFIGURATION - PHASE I # interface GigabitEthernet 1/1 encapsulation dot1q exit # # VLAN CONFIGURATION # vlan members remove 1 1/1,1/46 vlan create 100 type port-mstprstp 0 vlan members 100 1/1 portmember interface Vlan 100 ipv6 interface mac-offset 1 ipv6 interface enable ipv6 interface address 2001:DB8:0::1/64 exit vlan create 101 type port-mstprstp 0 vlan members 101 1/1 portmember interface Vlan 101 vrf vrf1 ipv6 interface mac-offset 2 ipv6 interface enable ipv6 interface address 2001:DB8:1::1/64 exit vlan create 102 type port-mstprstp 0 vlan members 102 1/1 portmember interface Vlan 102 vrf vrf2 ipv6 interface mac-offset 3 ipv6 interface enable ipv6 interface address 2001:DB8:2::1/64 exit # # PORT CONFIGURATION - PHASE II # interface GigabitEthernet 1/1 default-vlan-id 100 no shutdown exit # # CIRCUITLESS IPV6 INTERFACE CONFIGURATION - GlobalRouter # interface loopback 1 ipv6 interface address 2001:DB8:2000::1/128 exit # # CIRCUITLESS IPV6 INTERFACE CONFIGURATION - VRF # interface loopback 2 ipv6 interface address 2001:DB8:2001::1/128 vrf vrf1 exit interface loopback 3 ipv6 interface address 2001:DB8:2002::1/128 vrf vrf2 exit # # BGP CONFIGURATION - GlobalRouter # router bgp no synchronization exit router bgp 1000 enable router bgp network 2001:DB8:2000::1/128 metric 100000 neighbor "2001:DB8:0::2" neighbor 2001:DB8:0::2 remote-as 1000 neighbor 2001:DB8:0::2 next-hop-self neighbor 2001:DB8:0::2 address-family ipv6 neighbor 2001:DB8:0::2 update-source 2001:DB8:0::1 neighbor 2001:DB8:0::2 enable exit # # BGP CONFIGURATION - VRF # router vrf vrf1 ip bgp no ip bgp synchronization ip bgp enable ip bgp network 2001:DB8:2001::1/128 metric 100000 ip bgp neighbor "2001:DB8:1::2" ip bgp neighbor 2001:DB8:1::2 remote-as 1000 ip bgp neighbor 2001:DB8:1::2 next-hop-self ip bgp neighbor 2001:DB8:1::2 update-source 2001:DB8:1::1 ip bgp neighbor 2001:DB8:1::2 address-family ipv6 ip bgp neighbor 2001:DB8:1::2 enable exit router vrf vrf2 ip bgp no ip bgp synchronization ip bgp enable ip bgp network 2001:DB8:2002::1/128 metric 100000 ip bgp neighbor "2001:DB8:2::2" ip bgp neighbor 2001:DB8:2::2 remote-as 1000 ip bgp neighbor 2001:DB8:2::2 next-hop-self ip bgp neighbor 2001:DB8:2::2 update-source 2001:DB8:2::1 ip bgp neighbor 2001:DB8:2::2 address-family ipv6 ip bgp neighbor 2001:DB8:2::2 enable exit
# # VRF CONFIGURATION # ip vrf vrf1 vrfid 1 router vrf vrf1 exit ip vrf vrf2 vrfid 2 router vrf vrf2 exit # # PORT CONFIGURATION - PHASE I # interface GigabitEthernet 1/1 encapsulation dot1q exit # # VLAN CONFIGURATION # vlan members remove 1 1/1,1/46 vlan create 100 type port-mstprstp 0 vlan members 100 1/1 portmember interface Vlan 100 ipv6 interface mac-offset 1 ipv6 interface enable ipv6 interface address 2001:DB8:0::2/64 exit vlan create 101 type port-mstprstp 0 vlan members 101 1/1 portmember interface Vlan 101 vrf vrf1 ipv6 interface mac-offset 2 ipv6 interface enable ipv6 interface address 2001:DB8:1::2/64 exit vlan create 102 type port-mstprstp 0 vlan members 102 1/1 portmember interface Vlan 102 vrf vrf2 ipv6 interface mac-offset 3 ipv6 interface enable ipv6 interface address 2001:DB8:2::2/64 exit # # PORT CONFIGURATION - PHASE II # interface GigabitEthernet 1/1 default-vlan-id 100 no shutdown exit # # BGP CONFIGURATION - GlobalRouter # router bgp no synchronization exit router bgp 1000 enable router bgp neighbor "2001:DB8:0::1" neighbor 2001:DB8:0::1 remote-as 1000 neighbor 2001:DB8:0::1 next-hop-self neighbor 2001:DB8:0::1 address-family ipv6 neighbor 2001:DB8:0::1 update-source 2001:DB8:0::2 neighbor 2001:DB8:0::1 enable exit # # BGP CONFIGURATION - VRF # router vrf vrf1 ip bgp no ip bgp synchronization ip bgp enable ip bgp neighbor "2001:DB8:1::1" ip bgp neighbor 2001:DB8:1::1 remote-as 1000 ip bgp neighbor 2001:DB8:1::1 next-hop-self ip bgp neighbor 2001:DB8:1::1 update-source 2001:DB8:1::2 ip bgp neighbor 2001:DB8:1::1 address-family ipv6 ip bgp neighbor 2001:DB8:1::1 enable exit router vrf vrf2 ip bgp no ip bgp synchronization ip bgp enable ip bgp neighbor "2001:DB8:2::1" ip bgp neighbor 2001:DB8:2::1 remote-as 1000 ip bgp neighbor 2001:DB8:2::1 next-hop-self ip bgp neighbor 2001:DB8:2::1 update-source 2001:DB8:2::2 ip bgp neighbor 2001:DB8:2::1 address-family ipv6 ip bgp neighbor 2001:DB8:2::1 enable exit
