Perform this procedure to view remote SPBM nicknames on the switch.
- Select SPBM Remote.
- Select the Nick Names tab.
Nick Names Field Descriptions
Use the data in the following table to use the Nick Names tab.
Name |
Description |
Level |
Indicates the level at which the system displays this LSP. |
ID |
Indicates the 8 byte LSP ID, consisting of the System ID, Circuit ID, and Fragment Number. |
LifetimeRemain |
Indicates the remaining lifetime in seconds for the LSP. |
NickName |
Indicates the nickname for the remote SPBM node. |
HostName |
Indicates the hostname that the system displays in the LSP, or the system name if the host name is not configured. |
